Cub Cadet Z force 48
F2036
My Cub Cadet Z force has over 400 hours on the meter and has been a good mower.
Lately when pulling on the left hand control lever for that side to reverse direction, it doesn't want to reverse direction. The right hand side works great.
The left hand lever works the same as it always has it is just that the mower doesn't want to back up on that side.
Any thoughts or ideas on what to look at first or what the problem is would sure be appreciated. Thanks Jim
Check for loose linkages that could prevent movement for reverse. Also is the tranny on that side making any growling type noises when you try to go in reverse.
F2036
The tranny doesn't make any extra noises as far a I can tell. I need to take the deck off and check it out this winter, that will make it easier to check all of the linkages, I hope :) Thanks for the reply.
