TonyPrin
- Nov 4, 2014
- 14
- 199
Today I greased the front wheels of my XT1 for the first time using my pistol grip grease gun and Valvoline Multi-Purpose grease. The mower has four grease fittings at the front wheels, two on each side. The first fitting loaded fine with exess grease coming out by the fitting. On the other three fittings, excess grease came out of a seam where the piece with the fitting attaches to the wheel or the axle instead of at the fitting. Is this a common occurrence or is there a problem I should correct?
