Is there a tutorial on how to use this forum?? I am fairly good at this stuff but having trouble using this site. example srated a thread tyesterday saw some replies but now can't find them????
Someone asked me for belt numbers for the unit of discusssion they are: upper drive =954-04208 -smallest belt of 3 sits under seat, lower drive 954-0467 belt that engages the wheels and is under the main body of the mower-rather long , engine to deck 954-040608 cutting deck belt????
Got unit jacked up and seems to be working ok but deck is off. I assume that if trans is is reverse or forward and even at low speed the mower will mover ever so slowly without THE BREAK ENGAGED??? I have adjusted the lower drive belt tension riod but this does not seem to affect the operation BUT there is no creeping while I have it jacked up, in neutral and the deck off. I do admit I did not buy OEM replacement belts and after I put them on is when I started to have this creeping issue.
I find it hard to beleive that the creeping is coming from a belt issue but I am not that knowleagble iabout this/that.. TX for any and all input BOB
