Cub Cadet Debuts RZT S Zero Electric ZTR Mower
demhustler
And I was just starting to like cub cadet and they pull a stunt like this.
Next thing. Mowers will have is built in wifi
(( racing is the only sport that you need two balls ))
they sure will
demhustler
" In 2012, the Cub Cadet RZT S line revolutionized ... superior ... unmatched maneuverability as the first zero-turn riding mower to offer four-wheel steering controlled by an operator-friendly steering wheel..."
bs. please... if they already started with plain self- flatery, mesliading people and false advertising - well, good start
dem, Gismow ztr been here long time before : ))))
There are also these:
Recharge Mower - Recharge Mower G2 Riding Mower
Electric riding lawn mower
Hustler Turf Products - Electric Mowers - ZEON
demhustler
and also;
old GE elec-trak, 70-s
Elec-Trak Owners Club
15636d1373688670-cub-cadet-debuts-rzt-s-zero-electric-ztr-mower-ge-elec-trak-tractorbreakdown-jpg
and cub-cadet's bs "new, revolutionary" "4-wheel steering": on old Ox
The Ultimate Non Polluting Series of Electric Tractors for Towing, Mowing and Moving from the Electric Tractor Corporation
"The power is applied to each wheel separately by the speed controller. In a turn, the speed controller will apply less power to the inner wheel. This provides a light steering feel and a smaller turning radius than is possible with a traditional differential. In addition, an electronic differential simulates a differential lock while front wheels are driving straight"
Ric
There have been a lot of different company's that have produced these Electric ZTR and Riding mowers. None have never made it and the reason is there not a cost effective way of cutting ones lawn. There just to expensive for what they are and what they will do. Most homeowner's who are going to buy an electric are going to buy cheap and get a push to do their 4 or 5000 sq.ft. lawn, not 4 to 6000 dollars for a ZTR. Thing is and I believe they, the company's use them as a advertisement or sales gimmick to draw to people to there place of business so they end up buying something else.
Ric
Yeah I know and that's my point. The Normal Homeowner is only looking at maybe half an acre of land and not even that if you remove the 3000 sq. ft. area of house and garage so to spend that amount of money on an electric ZTR when a good $400 self propelled will do what needs to be done is something they just aren't going to do.
demhustler
$2,399.99 electric RER; 36-Volt, 85Ah = 3.060 kwh = 3kw [4.1 hp] for 1hour (at -1C and 100% efficiency) or 1kw[1.3hp] for 3h; 10-12h recharge; 450lbs[225kg]; 30'' blades
vs.
$1,499.99; 315.0 Lbs[142.88 kg]; 28"blades; 11.5hp [8.6kw] continuesly, for as much hours as you need
p.s. that's power to the ground, to the blades - mower is not an elevctric car or bike, there is no coasting, sitting in the trafic, gliding, etc - mower does hard work done continuesly, power take-off directly to the blades, 3600 rpm (or continuos, constant torque output at 18500 fpm blade tip speed); - this is all a continuouse work (load) - open cut, 20% for turns and overlaps as industry standard for performance mesurement
