Recently I just scored an older weedwhacker from an auction for a ditch cutter I have removed the carb carefully cleaned it and replaced the fuel lines as well as the primer bulb and now it will not even prime it almost sounds like I am sucking air when I try to prime the carb I have checked and rechecked my work any help will be appreciated
