Engine Craftsman with B&S runs great for 5 minutes, then dies
stevenwbennett
  • / Craftsman with B&S runs great for 5 minutes, then dies
I have a Craftsman mower with a Briggs Quantum motor. It runs great for about 5 minutes, then just dies. Then it won't start again until it cools off. I have cleaned the carburetor bowl and jet, and I ran some Seafoam in the gas tank. Any suggestions?
OutdoorEnvy
I'd check the air filter and around it to make sure it's not clogged and air is getting through cleanly.
Are you having to prime it a lot before it will start or in between starts?
stevenwbennett
Air filter is new and everything's clean. I push the primer 5-6 times and it starts right up.
OutdoorEnvy
So it will only start after you prime it again? If that's the case it might not be getting enough fuel when running and the lines could be clogged or something. If it's running fine and then dies it's usually either starved for air or fuel.
stevenwbennett
No, it won't start again until it cools off no matter what I do to it.
OutdoorEnvy
Well I'm out of ideas for my limited knowledge. I bet someone else smarter than me chimes in as I'll be curious as well. I run a B&S Quantum series too so it's peaked my interest if I ever have the same problem.
stevenwbennett
Yeah, what's weird (to me, with my limited knowledge) is that it starts and runs perfectly, then about 5 minutes later it just suddenly stops, as if you let go of the safety handle. No sputtering, just sudden death.
silver1
Check the fuel tank cap is breathing
- Check that you have the correct heat range spark plug.
- Check that the air flow around the engine/head is clear.
You must check for spark when it will not start to verify that
the coil is ok.
Good luck.
reynoldston
How old is the gas?
Fish
You need to buy some feeler gauges and check your valve clearences
