I've got a 2013 Craftsman Weedwacker 4 cycle 30cc trimmer that someone gave me that is bogging down when you give it throttle, It will die. Wouldn't run at all when I first got it. He was tired of messing with it. I went thru the carburetor and used carb cleaner on it with pressurized air, replaced the metering diaphragm, replaced the fuel lines and purge bulb. Starts right up on full throttle with full choke position 3, runs pretty good in half choke position 2 but on choke off position 1 idles fine but bogs right down with throttle. This is a walbro WYLA 3 carb with external bulb and does NOT have the low and high speed adjustment screws. Only adjustment is the idle speed screw on the throttle. So what should I be looking for now? Air leak maybe on gaskets. Maybe replace fuel pump diaphragm? Replace the whole carb with a new one $12. Maybe try and adjust the needle lever using the needle level tool? Appreciate any suggestions.
