johnnyvv2003
- Sep 24, 2014
- 1
- 4
Hello everyone...
I have a Craftsman tractor Model 917.271014 with a 15.5hp Kohler engine. It has been giving me some problems for some time but recently it just suddenly bogs down and back fires. I went to use it this week and cant even to get it to stay running. It almost sounds like timing to me but I'm not sure what to look for next. It actually ran yesterday while I was working on it then suddenly just shut down. I'm thinking this is electrical just by the way it was runnning fine then suddenly misfired and shut down.
Here is what I have done so far:
Cleaned the carb fully (also tried to use a little starter fluid to see if it was a fuel issue but I get no chancge when sprayed directly into he carb...Actually it seems like it floods it)
New Plug
New Fuel filter
Removed valve cover and checked valves and rods - There is no adjustment on this engine for the valves
Removed Head and checked for scoring (none)
Checked spark at both wire and plug - Good spark
Removed flywheel and checked key to ensure it is not sheared
cleaned the terminals on the ignition magnets
Cleaned electrical connections.
Sorry for the bad video but this will give you an idea of the best I can get it running.
[video]https://www.youtube.com/edit?o=U&video_id=4mvDIkN9ikA[/video]
Any help would be great!
New Plug
New Fuel filter
