davidmichael52
- Nov 25, 2020
- 1
- 2
Its only two years old and it just quit running as i was mowing. Just stopped. It will turn over and seems for like a second it will start and quit atomatically. I changed spark plug and tested it with a spark plug tester and i am getting a spark. I took off the gas line to the carb and gas is running out at that point. I changed fuel filter,air filter and still wont start. I took the fuel solenoid off and the plunger is free. should i just buy a new carb and change that? Also i am unable to remove the connector on the side of the fuel fuel solenoid someone said id have to get a screwdriver and push in on the side and at the same time pull it off. I still cant seem to get it disconnected.
