craftsman t1500 ground drive belt help
mark60
craftsman t1500 247273740 came to me with a broken wheel drive belt i found the belts but there is no diagram under the tractor. i can not find the routing for the belt. you t search did not find any thing that looked like this machine. any help would be appreciated.
This maybe the closest you will find a diagram from MTD/SBD in some cases. 1752397053277.png
But you can go find a similar Troybilt, Cub Cadet, Etc with the same pedal configuration as your mower at a box store and have a look under he mower., and doesn't have to be exact same model, because MTD uses the same belt routing on all of the variabe speed gear shift style mowers.
mark60
thank you that's just what i needed.
