Craftsman T-3200
pmc6249
I'm working on a Craftsman T3200 tractor. The problem I have is when you go in reverse on a hill and left off of the reverse pedal It free wheels backwards even if you push on the forward pedal. You can also hear a clicking noise coming from the transmission. If you hit the brake and come to a stop it will travel forward again normally. Anyone encounter this issue and found a fix?
Free wheeling backwards down a hill? Why would you need reverse on a hill? Neutral might be better??
