Craftsman riding mower had a hard time going up hills
ghosthorse
  • / Craftsman riding mower had a hard time going up hills
Craftsman riding mower Model 917.276882 26HP Kohler engine. Just changed 1 broken pulley and drivebelt. Tractor will mow with belt engaged, but bogs down to a snail's pace when driving up a hill. Cannot tell if there is a belt or engine issue. Changed oil and cleaned air filter. Not sure if it is a PTO problem but pulley seemed fine.
mechanic mark
See Ground Drive Assy: Did you replace idler pulleys with Craftsman OEM belt?
ghosthorse
Whenever the drive belt is replace both v-idlers should be replaced. BTW drv belt is 1/2 x 84-1/2.
If engine rpm don't change a lot going up hill then it is the hydro or belt slippage.
ghosthorse
Do you mean the hydro transaxle?
