I recently completed a robotic lawnmower project using an old Craftsman push behind mulching mower (917.388621) with a 6.75hp engine (143.016702). Actually, the mower is not entirely robotic at this point, but computer control is in the plan for the next stage in its evolution. Right now, it is self propelled using wheelchair motors, standard 2.6ghz r/c remote radio control drone technology, and a real-time 5.8ghz FPV video feed.
The electronic technology seems to be working pretty well, but the reason for this posting here is because I suspect a basic problem with the gas mower engine. The mower's mission is wildfire mitigation of my steep backyard terrain which grows waist-high native grasses, thistle, cactus, and an occasional rattlesnake. The remote control and video feed is helpful in avoiding the latter.
The specific engine problem I'm having is that when the mower encounters particularly dense or stringy vegitation and I don't back it off quickly enough, it will stall and I can't get it started again with the pull rope. Then I have to wait up to 1/2 hour for it to cool off enough to restart. It always seems to start very easily when cool.
From internet research and my engine-savvy neighbor, we suspect the problem may be with the carburator and possibly the automatic choke / governor linkage. I ordered a replacement carb which has not arrived yet, but also have have not found any adjustment instructions for the governor linkage towards the rear of the engine. I notice that when the adjustment screw is loosened, and the governor arm is adjusted rearward, the throttle valve closes. The loading of the linkage spring (when the engine is cold) pulls the governor arm frontward which opens the butterfly throttle valve.
My neighbor suggested that the governor or choke system may be reducing fuel/air when engine rpm drops in advance of a stall, and this may be why the engine is stalling. I am more concerned about having to shlep the robot back up the hill to the workshop, or wait out with the cactus and snakes for it to cool off enough to restart.
Can anyone suggest an adjustment procedure for the governor/choke linkage that will: 1) provide additional fuel/air to prevent stalling; and 2) make the mower easier to start when hot?
Thanks so much for your suggestions.
