timsstang87
- May 14, 2011
- 1
- 2
Hey guys I am new here and have a question hopefully someone can answer for me. I have a Craftsman 22" cut (model 917..75500) with a Briggs and Stratton 6.0 (model 22K02 0577 051116 F8). I left it outside last winter and went to use it this season and it started and ran for about 30 seconds, then shut off. I have since drained the fuel tank completely, and filled with new gas, put a new spark plug, and changed the oil. I have taken off the carb and cleaned it completely. The only way I can get it to keep running is to constantly push the primer bulb while it is running. Could the air filter have something to do with this. I have not replaced it yet. I did notice there is a vaccume tube that runs to the side of the air filter housing, does this get vac from the crank case pressure, and could it be plugged? Any thoughts/help on the matter would be greatly appreciated.
