I have a Craftsman lawnmower model 917371030 with. Briggs engine model 11P905-1267-B1. I have a had a hard time starting. I could spray a little carb cleaner and it would start, still hard but start. I rebuilt the carburetor put in a new spark plug gapped the magneto/coil tested the spark by placing a spark tester in series with the plug and high tension plug cable and when I start the engine I get solid light flash in the tester. But the engine doesn't turn over. I have good compression. I can feel good vacuum at the carburetor and smell gas getting to the carburetor and there is gas in the float bowl. I can shoot some carburetor cleaner into the carburetor and it still won't turn over. I can't help but think the coil even though it looks as though it is providing spark is not hot enough to fire the engine. Any help would be appreciated
