A guy gave me this mower and today I replaced the belt and blades. Their seems to be no tension adjustment available on this model. I can only see where there is a pre-sized metal bracket that has two attachment points...: the first is to the upright by way of a cotter pin and then it attaches to the sliding bracket in a pre-cut hole to ...I am guessing...give it the required pre-determined tension. Used belt 144200. I cant see on any diagrams where anything else is attached to increase the tension. The blades start turning immediately upon the engine being started. The engage/disengage lever seems to be connected to a spring to depress the kill switch but on the attachment end to the deck it only connects via another cotter pin on a bracket and the bracket connects to nothing else....I see no brake pads or anything on the pulleys anywhere.
Anyone have some information I sure would appreciate. Thanks Scott
