Craftsman Lt4000 engine died when engage blade
Jeanphilmartel
Engine run good , no problem but when I hit the blade switch it take 2-3 sec and engine lose power and died !! Please help me
keakar
it wasnt in reverse was it? it happens
test the operation of the spindles and pulleys to see if they are free or if the bearings are shot
nbpt100
If KEAkar's ideas did not solve your problems check to see if the Carb is too lean. If you can richen the mixture try it.
