This engine has recently started having a problem with blowing oil out of the dipstick tube if removed during operation. It didn’t do this last season. I verified the crankcase breather is open and not clogged, checked the head gasket (it was GOOD before removal), and checked the cylinder bore for any damage. The bore looks perfect, though I haven’t removed the piston to look at the rings. The compression is very good and the engine does not smoke at all. I havent seen oil coming out of the fuel pump, but there is a little oil residue in the intake tube between the carburetor and cylinder head. pushrods are perfect, and the valves appear to be sealing well. I’m considering ordering a few gaskets, a set of piston rings, and just re-ringing it and hoping the problem clears up. Any ideas or help?
