Craftsman LT1000 Steering
Grizzly Adam
Good afternoon all, first post here! Can anyone make some recommendations to smooth out the steering on a LT1000, it has quite a bit of play and is quick to turn once you get past that. I replaced the steering shaft and assembly last year so I think we are looking at mod territory here.
Have you checked the condition of the lower steering shaft bushing and sector gear. Wear of either or both of these parts will contribute to your problem.
Lots of debris will build up around the fan gear which needs to be regularly cleaned out.
The fan gear needs to be lubed your owners manual says to oil daily which you can not do unless you worked in a circus.
Most of us use spray grease after blowing all of the debris out using a very long air duster .
Grizzly Adam
The sector gear was replaced as part of the assembly. I don't recall their being a singular bushing, only the ones in the axle assembly, which are all about 3 years old.
Grizzly Adam
I assume you are speaking of the same pat as Rivets, and it is new, clean, and lubed.
Grizzly Adam
I found the steering bushing on the diagram, pn#155099. I have not replaced that part so I will add that to the list. I am also looking at replacing the plastic axle bushings with metal and adding thrust needle bearings.
