Craftsman DYT4000 sit down lawn tractor wont start
OliverWolfDog
I have spark to the plugs and it won't start even with starter fluid. Any ideas why it won't start?
mechanic mark
Post Model # from under seat. You need the following for engine to start: check engine oil level on dipstick, add to full if low, fully charged battery, fresh gas in tank, engine compression, check air & fuel filters, good spark. Remove spark plug & inspect for replacement or clean gently removing carbon & check gap at .030 with gauge reinstall & give her a try. If no start you will need to check valves for adjustment, compression release may not be functioning properly. Do not panic, we can walk you through procedure, most important: we need engine information.
Post all information from engine, thanks, Mark
OliverWolfDog
Thank you for your reply. I was able to get it to start. Found out that the fuel line was clogged. So I am replacing the fuel line and filters.
Dump the tank out while you are at it.
