OK, my daughter's husband died a month ago and he left her with lots of broken equipment and over grown 2 1/2 acres. My neighbor has tracked the problem down to a Ignition Module. But finding a replacement for is driving us crazy. I've had lots of place tell me what module we need, some are selling two packs and are conversion kits that will replace both coils. Then I just got an e-mail from a parts place and they suggest a lot of different coils, some say before conversion coils and then also show after conversion modules. I thought maybe someone else has had to replace this part and would be able to steer me in the right direction. I've attached the data tag that gives a lot of information about the motor. It's a 2 cylinder, only one bad cylinder, 26 HP with a 54" deck. It runs until you put a load on the tractor or going up a hill then it just dies but when it is running you can smell that it's burning gas. My 93 year old neighbor is very good at most everything and he tested the cylinder and switched out modules with the one working then the other cylinder doesn't work so it must be the coil. I have so many different modules streaming through my brain and my neighbor's brain it seems impossible for there to be so many different ones that "might" work. Any help would be greatly appreciated before they haul me off in a straight jacket.
