peddle not releasing and it is staying flat to the floor.
J jim_dian_hall_travelers@y Forum Newbie Joined Sep 20, 2021 Threads 1 Messages 1 Sep 20, 2021 / Craftsman 6000 Lawn mower # 917.288613, 2003. peddle not releasing and it is staying flat to the floor. #1 peddle not releasing and it is staying flat to the floor.
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,687 Sep 20, 2021 / Craftsman 6000 Lawn mower # 917.288613, 2003. peddle not releasing and it is staying flat to the floor. #2 You’re going to have to remove the deck, crawl under and check for the following. Broken or missing return spring, bad drive belt or idler pulleys, pinched belt. I’m betting you’ll find a return spring problem.
