cracked gas tank
innerview
I have a cracked gas tank - plastic - on a Lawn-Man with Briggs engine...
Can you recommend something to PATCH and Seal it? Or will it have to be replaced?
thanks!
reynoldston
Seal-all comes in a yellow tube and you should be able to buy it in most hardware stores. I have used it for years for gas leaks but make sure your repair is very clean.
innerview
Can't thank you enough, my friend.
I'll pick it up this week!!!
