Cr. gcv-160-A1AE has new carburater, starts but won't run
minimor
  • / Cr. gcv-160-A1AE has new carburater, starts but won't run
As far as I can tell, the parts are all correctly assembled again , and it will start, but won't continue running. I've tried moving the throttle in varying positions, and it still won't continue running. I have taken the whole thing apart and checked that all are in the correct lineup, but it just won't continue running after starting. Any suggestions or infor appreciated.
It seems the amount of gas is not suitable to it, -or air- but I don't know how to go forward with it. It says in the literature that the carburater is set in the factory, though I see screws that suggest movement could be made possibly, so what do I do now? thanks.
