My JD 855 compact utility tractor came with calcium chloride loaded in the rear tires for ballast. This is the 2nd time I've had to address leaks due to the valve cores rotting out. The rims are pretty rusty now too. I considered getting new tires and rims and adding a non-corrosive liquid, but the options for 33x12.5-15 turf tires are extremely limited and I'd be looking at over $1,000.
Instead I'm going to have a local truck and heavy equipment tire dealer repair the rims as necessary and fill the existing tires with foam. Hopefully they'll provide enough ballast. The machine is used mostly for light duty chores on my own property these days and I'm looking forward to not having to worry about air/fluid leaks anymore. I'm grateful that the backhoe outriggers make it so easy to pull the wheels.
I tried to upload photos but the files are too big. I never had that issue before the software update.
