MellBell76
- Sep 6, 2021
- 1
- 1
Hello there! I would like to know if I am reassembling this correctly. Plate does open when parts are moved manually .
Reassembled (Please ignore the fallen gaskets I removed the screws and filter case for photo, and of course they f
When assembled I believe this is the plate in the closed position
Plate opens when I manually adjust the throttle arms (Sorry that’s not the correct part)
Plate opening when I adjust the choke lever manually
