i have a customers Coleman generator with Briggs 6hp engine OHV 120342-0137-E2, has only 60 psi, it is back firing through carb with flames sometime, i had it started for like 2 minutes, i have checked flywheel key, cleaned gapped plug, rebuilt carb, check coil and gapped. checked OHV they seem ok, what next??
