I have 5 old 3-4 h.p. b&s engines. 2 questions. How do you test the condensor? What is part number and good place to purchase an eloctronic magneto for these engines, in particular model # 92908 2059-01 79110225 and92902 1279 01 75060? Thanks
The part number for the module is 591420 which may not look like the one that is on it now.
Does this part eliminate the points and condensor?
Thanks for the help. Originally I listed 2 model numbers will that part number fit both? Also what website are you using to look these up?
