Clutch
garngail
Older Deutsch-Allis 612 lawn tractor. Clutch is very jumpy when releasing,
Can it be adjusted?
Before trying to make any adjustments, first check the condition of the belt. I’ve found that most times a bad belt is th most common cause. More than three years old, I would consider replacing it. When you post back please include the model and serial numbers for your unit and I’ll see if a service manual is available.
