Okay. So I'm trying to replace a drive belt in the dark on a 2009 craftsman lts2000 917.289081. I ran it around on of the guides wrong n when I tested it. It slipped n got hung up above the clutch /brake pulley. So I had to loosen it causing the spring or something to sprung. Pulley came off. Now next day I'm trying to reset it correctly. I can get the pulley assembly back together but it doesn't want to move. There must be something I have to depressed to make it spring loaded again?? Thank you for your help
