Hello - I have a Toro Timecutter 4260 and I recently had the recycler attachment added. Since adding the recycler, I've had considerable challenges with clumping and grass buildup under the deck (I now have to clean the deck by scraping the grass off or using a power washer).
I know that the recycler is not supposed to be used on wet grass so I usually wait 48 hours after a rain to cut my yard (I would rate the grass as 'slightly damp' when I cut it).
Has anyone had experience using the recycler attachment on a Toro zero turn? If so, what has been your experience with clumping and cleaning challenges. Any advice on this would be greatly appreciated.
Thanks,
Jeff
Thanks,
Jeff
