Clicks but won’t start
Magnum54
Badboy magnum right at 2 years old. Starter solenoid clicks continuously while turning key to start position but will not turn over. It looks like the starter is turning but not engaging “popping up to turn the flywheel to start the mower”. Replaced the started solenoid. Still nothing. Battery has atleast 12.5 volts. Battery negative to battery side of the solenoid has 12.5vdc +- the other side of the solenoid with the key turned only has around 4vdc. Less than that when checked at the starter. Pulled off instrument cluster cover and checked switch for continuity and has it there. Checked between S and the white wire on starter solenoid and it has very little voltage. I’m lost on this. Any help would be much appreciated.
Before you start, pull the spark plug & try to rotate the engine by hand.
No use checking the electrics if you have a hydraulic lock, seized engine or jambed belt overloading the stater motor.
Assuming the engine turns freely.
I like to start from the starter motor and go backwards .
Do the following 5 tests, regardless of the results from an or all of them as there can be more than one problem and you want to isolate where the problem lies.
Elimination of individual parts is important so you know by the end, the battery, solenoid & heavy power circuits are all in good order.
1) try to jump the starter motor directly from your car or truck.
+ on the starter first then - to a good ground near the starter ( drain plug of lift hook are good )
Starter turns = starter good
2) do the same directly from the mowers battery
Starter turns = mower battery good
No turn = duff battery, recharge it & try again.
3) check for voltage ( + 12V ) at the solenoid trigger wire with the key in start position
3a) same with ground trigger wire ( 4 wire solenoid ) or body of solenoid ( 3 wire solenoid)
( I like to test V from the battery hot terminal to ground terminal rather than ohms as they give funny readings )
4) leave ground jumper in place ( from step 2 ) & try key start.
Starter turns = power connection good but ground connection suspect ( most common )
Confirm it by trying again, extra ground removed
5) Remove the trigger ( thin ) wire / wires from the solenoid.
Ground one on a 4 wire solenoid & bridge from the hot terminal to the other.
Starter cranks = solenoid good.
Solenoid is not polarity sensitive, BUT THE WIRING IS so make sure you remove the thin control wires.
Note a thinner wire on the hot terminal is not a control wire. It is the main power feed to the mower.
From here on things become very mower dependant as starting circuits are getting changed all the time.
Basically the power goes in a loop from the hot side of the solenoid ( saves wire, no other reason ) through the fuse to the B terminal on the key switch then to the PTO switch then to the parking brake switch then to the solenoid trigger switch , easy peasy after you grow the 3rd arm. Use a test lamp and follow the power.
However a lot of mowers with a 4 pole solenoid, run a secondary ground control circuit to the ground solenoid wire through the lap bars.
Then to stop this interfearing with the normal safety function of the ground kill, it goes to a relay with the ground as the switched connection.
These are a PIA as the + control wire to the relay comes from the power loop above and the ground side of the control comes via the normal cut out functions of the lap bars.
Be very careful because if you have a system like this and accidentally send 12V down the ground loop you can fry the magnetos on some circuits.nd from the grounding bolt to one of the starter mounting bolts & paint over both with liquid electrical tape.
dn12005
New member...just signed up today to tagging along on this OP. My mower is also two years old and I just ran into this issue. I used the mower just this past Saturday without any issue. Parked for two days and I get this: different from what the OP described, when turning the ignition switch, I hear a humming sound that appears to come from the starter (or possible the solenoid).
Any assistance will be greatly appreciated.
Hardluck
Did you get this resolved... Have you tried to charge or replace the battery?
PLEASE DO NOT TAG A NEW PROBLEM ON THE END OF ANOTHER POST
IT GETS VERY CONFUSING AND IN THE LONG RUN HINDERS MORE THAN HELPS
IF YOU WANT HELP START A BRAND NEW THREAD COMPLETE WITH THE MODLE & SERIAL OF BOTH THE MOWER & ENGINE
