Grhopper
- Apr 18, 2021
- 2
- 9
2012 Classic T 2750. With engine off and switch in on position, I turn the PTO switch to on and hear a click. I have 12 volts coming from the clutch pigtail. With engine running, when I turn the PTO switch on, I can see the belt try to move a little, but doesn't engage. Prior to this I would notice the blades slowing down when cutting grass, then speed back up to normal operation when over areas that were already cut. What should my next troubleshoot be?
