msdeerhunter
- Apr 14, 2014
- 4
- 16
Good morning! I have a 26 hp engine, model 44P777-0124-G1. The only way I can get it to start is to spray a small amount of carb cleaner or starting fluid in the breather. Once started it runs fine. I noticed that once started I can leave the choke lever pulled up and the engine doesn't run any different. That's telling me the choke isn't working properly. I can manually push the linkage with my finger and the choke will not close. Will a tune up kit for the carb fix this? I have taken the carb apart and cleaned everything with no luck. Everything seems to move freely. Any ideas how to fix this? Thanks in advance!
