China mower-Master Craft
bogdaN
I got this thing free---free is good,but missing some parts and nothing cumming on line.The engine is made by Loncin ,I need control rod for auto-choke and air filter box.I have the engine running Ok.
label in pic #2 is unreadable.
Scrubcadet10
Moderator
Staff member
do you know the CC of the engine? Usually says right on top, like 6.5 HP, 210 CC, etc.
Hammermechanicman
Loncin makes a lot of the Honda clone "chonda" engines. How about a few pics of engine and carb?
bogdaN
Well kinda strange the emissions label did narrow down which engine it has. LC1 P65FC (2 .7 kW), LC1 P65F-2 (2 .7 kW)
If I did find the correct engine model then the Throttle/choke linkage is Loncin PN 171650004-0001
Air Cleaner Assembly
PN 180020403-0001
Unable to upload IPL here. I will need send link via PM if needed.
bogdaN
PN 180020403-0001
Have more pic,s and questions.Do i need to look for more numbers on engine?
Loncin electro etch their engine numbers on the crankcase .
They are quite feint and usually large letters made up with small dots.
Generally behind the carburettor.
