Float chargers have solved the problem of cooking your battery (go along with that for the moment even if you disagree). I have always been an advocate of disconnecting the battery from the rig and then attaching the float charger. However I wonder if that is even necessary these days. What are others doing or what do you recommend. Disconnect the battery or leave it connected to the electrical system, during storage while it is connected to a float charger?
