I'm having quite a bit of trouble figuring out what is worth with this engine. Carb has sat with water and fuel in it and when running the exhaust glows and has a flame coming out of it.
Things I've done so far:
Magneto driven ignition update + plugs
Inspected bottom end timing components
Inspected flywheel key
Replaced lifters that appeared to have stuck baskets
Carburetor cleaning
Nothing has made any improvement in running rich and burning fuel in the exhaust.
I didn't check after the new lifters but before the swap the base circle of the cams seemed to have pressure on the valves. Does this engine use different length push rods for intake and exhaust? Maybe they got swapped at some point.
I'm torn between getting a cylinder leak down tester, just getting a valve job done, and swapping the carb.
Any thoughts would be appreciated.
Carburetor cleaning
