Fordoldfart
- Mar 6, 2021
- 2
- 4
Does this look like a blown head gasket. It started using a lot of oil. Did a compression check what I would call #2 cyl had 160 psi #1 only had 90 psi squirted some oil in #1 and got the to 160 psi figured it was rings might still be but I took the number #1 head off and the bolts weren’t very tight and this is what I found
