PTmowerMech
- Apr 16, 2018
- 387
- 2,956
CH23S
Spec: 76510
Put it in the WOT position then back off, the governor keeps it at WOT. But I can manually move the gov arm to low idle, and it'll stay at low idle.
The governor problems I've had in the passed, if the gov. was bad, the engine would either stay at WOT or would go right back to WOT.
The linkage is free, and easily moves with just a finger.
I've sprayed some WD40 around the linkage and the governor rod, let it sit for about 10 minutes and blew it all clean with compressed air.
Commercial customer says he hasn't messed with it, so I'm thinking it's just a spring missing, or has been put in the wrong hole?
Or am I completely wrong about that?
Spec: 76510
