Hi All
I have just bought a CatelGarden EL63M (not sure who the original manufacturer is but I have seen these branded as Mountfield amongst others). Anyway, I have a few issues and I wanted to maybe strip down and give it the once-over. Does anyone know if there is a service manual available for this? Also if anyone knows exactly which Briggs & Stratton engine is fitted to this mower that would be useful. Issues I have are:
1). Engine hunting - suspect governor spring - that why I need to find out what engine it is!
2). Bolt that holds the deck to the adjustment at the front left of the mower has snapped - suspect it wasn't the right one in any event
3). Bolt holding deck to engine at the left hand side missing
4). One of the belt guides has dropped off so need to know where it re-attaches
I suspect the above are contributing to a heavy vibration when I engage the cutting blade.
Any help would be much appreciated.
Cheers
Sean
Cheers
Sean
