carburetor
woodmaster
would anyone have a carb for a briggs model 133402. the carburetor number is 495652, i cannot find one any were. the one i have leaks fuel i done everything i know and can,t stop it from leaking. any help would be appreciated.
Most likely the rubber seat for the needle valve is cocked to the side, or damaged. I have to keep spares around even when doing carb kits, because they are easy to damage when installing, and will swell if exposed to carb cleaner, as well as come apart.
EngineMan
Replace the needle and seat the part number is 398188 or.....click the links below...they do work..!
Error
Error
