Hi everyone,
I'm not sure how this works so I'll just send my problem out and see what happens.
I have a Toro walk behind self propelled mower with a Briggs and Stratton 6.75 engine. It is about 9 years old. It was running very slow and hard to start. It does not have an adjustable throttle. So took the carburator off and cleaned it , replaced gaskets including the float pin and small rubber ring that the float pin fits into. Still won't start. Also removed cowling and cleaned up the ignition coil and the magnets on the fly wheel? I spray starter fluid into the carb and it will start and run until the starter fluid is gone. I've checked the gas flow and it seems to be fine, as I replaced the gas line as well. Checked compression by holding finger over the sparkplug opening and there seems to plenty of compression.
Any Ideas
Any Ideas
