Lots of carbon removal products out there. What do you guys use to de-carbonize cylinders, heads and valves?
Bet a lot use wire brushes on a drill. Not a fan of those from all the metal removed and scratching that soft aluminum.
Numerous sprays and dips out there.
What is the best procedure at this? Love to hear from some that have tried them all. This one magic method is the ticket.
Here's an answer from Briggs.
How to Remove & Clean Carbon Build Up | Briggs & Stratton
Remove carbon buildup to keep your small engine performing strong. Learn how to clean deposits off the cylinder head and wall, pistons, & valves.
www.briggsandstratton.com
