does the twin cylinder engine throttle have a return spring?
what closes the throttle when you reduce speed on the speed control lever?
my governor arm is hanging laying there with gravity holding it wide open all the time
when i got this mower the governor was tied down with a spring to just run at slow idle and the engine had a bad governor that i replaced but the rpms are still running away on me like crazy
there seems to be signs some goober wannabe mechanic was messing with this thing and may be the one who grenaded the governor in the first place but the engine is unharmed as far as i can tell so i replaced the governor and now im trying to get it running right
the intake manifolds be literally cold to the touch, like soda from the refrigerator cold. i dont think thats right so im just wondering if i might be flooding there causing the cold condition?
its the Briggs & Stratton 44N877-0003-G1 24hp twin cylinder with automatic choke
when i run the engine, the intake manifold is cold to the touch at the split coming out of the carburetor going to the heads. its cold like grabbing a soda from the fridge cold, which seems very odd to me, i realize atomized gas has a cooling effect but still i wouldnt think it should get cold like that with ambient 80 degree air temperatures here so im wondering if its a sign itsm flooding?
this is the manifold im talking about thats cold after it has been running https://i.ebayimg.com/images/g/FEoAA...s5/s-l1600.jpg
also testing the linkage with engine running or off, the throttle pushes up the linkage for the choke, and pulls down on the throttle for wide open throttle, but when you pull back on the speed setting lever, the choke arm drops down to turn the choke off, but there is nothing that pushes the throttle closed so it stays wide open all the time
there has to be a throttle return spring or something that is missing on it that closes the throttle when you reduce speed
the governor i installed was set correctly, set throttle wide open, turn governor shaft clockwise until it hits then tighten the nut
