8 HP B&S from '94 (powering a woodchipper) spits fuel while running. Engine sat for years. I replaced carb with new aftermarket carb. Only carb available. Engine starts and runs, no surging. Engine running at low speed fuel is seen gushing from brass pipe from fuel bowl to throat of carb. At full speed all fuel is going into cylinder. Engine exhaust is black from too much fuel. At low speed it puddles up at throttle valve, then drips down Air/Cleaner side. Engine vibration normal. No fuel in oil or coming from exhaust or crankcase breather hose to air/cleaner. Engine off, no fuel leaks from needle/float. Is fuel pump pumping too much fuel? I changed fuel tank to gravity fed. No change in carb behavior. What causes this? If fuel needle/float not leaking with engine off, why is too much fuel being pushed out of float bowl when engine on?
