Can't get the head off a Homelite ST-145 String Trimmer.
Vintshave
  • / Can't get the head off a Homelite ST-145 String Trimmer.
Trying to replace the string on my trimmer. Watched some videos but it seems like the end knob won't unscrew even with a good deal of force. Am I missing something?
Most likely you going to need to cut the plastic knob off the bolt as it is seized. I have seen this on several of these over the years where they over tighten themselves and seize. I personally got an old ST285 that did it eve nwith a new knob then I started using anti-seize compound on it which seems to cure the problem.
BTW that know is already worn out and allowing moisture into the area of the bolt and threads.
Vintshave
Do these loosen with a left turn or right? Just checking
upupandaway
I recall it is LH thread.
Black knobs are normal right hand threaded and red knobs are left hand threaded. As I said just plain stick sometimes even when new ones are installed and this one is worn out and probably has lost the seal over the hex head screw (bolt).
