Cant get drive pulley off
cantfixshit
I need a little advice, i was trying to take apart my snappper 2690848 motor to replace the govenor. I first tried pullin, didnt work, used even a grinder to get it off. It looks like its almost molded as one piece. Is this possible?
Torch of some kind and quenched with cold water.
PB Blaster soaked for a couple weeks prior.
Air hammer.......
Here I use a bearing separator/puller with a sacrifical spacer, a strong impact, and ace/ox torch when the pulley is beyond saving. But first would tried the harmonic balancer puller since there were three puller holes, an impact, and ace/ox torch.
