Can someone please help me
Melonman863
I have a tiger cub 48 and the drive belt for rear tires broke I cant find anything that shows how to put belt on can anyone help me out on this I'd greatly appreciate it
Reverse it up some car ramps ( not easy with no power ) or otherwise get it about 1 foot off the ground.
Make sure it is very stable because if it falls while you are under there you become lawn fertilizer.
The belt is a strait triangle from the engine pulley around both the drive pulleys .
They are a long way up and not easy to get at,
The tension pulley pushes in on the exit side of the belt
Take the spring off
Generally there is a square hole in the tesioning arm for a ratchet or breaker bar.
jekjr
Belt goes over the two pumps pulleys inside of the two idlers and over the pulley on the motor. I normally put it on everything but the one on the motor. Then You have to take a 1/2" drive breaker bar and take the tension off of the pulley and that will give you the ability to put the belt on the pulley on the motor.
Hope that helps. I always put them on with the mower sitting flat on the ground. Have installed them numerous times in the field.
Melonman863
Thank yall all very much I'm gonna get it in garage and try it out thanks again
