MowerMark
- Mar 1, 2014
- 55
- 263
RECENT THREAD: http://www.lawnmowerforum.com/small...ccasionally-slows-shakes-smokes-start-up.html
So following the owner's manual, the oil was drained. Used AMSoil 10-30 synthetic to fill the tank. The problem is that the oil level is difficult to detect.
1. The oil is clear so the line is difficult to visualize on the stick, and
2. Oil seems to coat most of the stick.
Maybe 0.4 liter was added.
Ran the engine for a few minutes, then waited ten minutes and still the oil level on the stick was no clear. Emptied some oil out, and still cannot determine the level.
QUESTION: Can the oil reservoir actually be too full, and if so, will it actually cause damage ?
Thank you.
Thank you.
