Bronco dies when put in Forward
Soonerbob61
My Bronco dies when I put it in Forward position.......I was told that if you let the blade engage handle "slap back" into the disengage slot it will fix the problem.....and surprisingly enough it did at first but now it won't go at all in the forward position.....It will stay running in reverse.......is there a sensor or spring that needs replaced?
